johnson 70hp 2 stroke 1995 shut down when warm
gabd
hi everyone ,
im pretty new to the world of boating
i recently bought a little 16foot bowrider with a 70 hp johnson 2 stroke .
im the third owner since purchase brand new in 1995 the is solid and the engine run like a charm.
yesterday i took it for a ride with my friends and as usual the boat start very easily and run very smootly ....
after an hour i was cruising around 4500 to 5000 rpm the engine die by itself .....i was able to restart it very easy .....but after 5-10 minute he die again and he get harder to start. i was wondering if someone had the same issues and the past to help me finding where to start my investigation .
its important to me to do the rapair by myself because i want to learn everything about this engine .
thanks you very much
gabd
hi everyone ,
im the third owner since purchase brand new in 1995 the boat is solid and the engine run like a charm.
after an hour i was cruising around 4500 to 5000 rpm the engine die by itself .....i was able to restart it very easy .....but after 5-10 minute he die again and he get harder to start.(need to put throttle to the max while starting and put it on the gear very fast to keep it running) i was wondering if someone had the same issues and the past to help me finding where to start my investigation .
its important to me to do the repair by myself because i want to learn everything about this engine .
thank you very much
saltchuckmatt
hi everyone ,
Well if it sat for a long time before you purchased it my guess it's fuel related. (Tank, hoses, carbs....) But it can be lots of things. Most on here will want model number, compression test numbers, spark test, etc. Then they will comment.
gabd
hi there .
thanks for helping me out
i do have tested spark and everything is fine
havnt check compression yet and i will provide the model number when im back home tonight
tphoyt
Agreed with above. Has the water pump been serviced since you bought it.
That’s always the first step to a new to you motor if it’s age is unknown.
Oil injection in service ? ----Tested ?----Bypassed and mixing oil and gas at 50:1 in the tank?----Or no idea.-----Overheat horn tested ?
gabd
the engine is oil injected
i dont know when was the last service of the water pump but i noticed she was working
the engine havnt over heated
Post compression test numbers.----Install a new water pump impeller.-----Test run with another tank and hose.
gabd
okay i will
do you have any suggestion for a good place to order parts ?
im in canada
Where in Canada ?------evinrudeparts.ca-----Along with this site here.
gabd
thank you so.much
im near vancouver in british columbia
evinrudeparts.ca ----can offer free shipping on orders of $79 or more.-----You need to do some trouble shooting / testing before ordering parts I say.---I suggest the latest water pump kit with instructions.
gabd
i bring the boat to my friends garage tomorow i will get the compression of the 3 cylindre and investigate more in this direction .....i will double chek fuel filter, line and pump .....do you know any way to test the water pump ???
Impeller should be replaced about every 5 years.----But test your overheat horn.
gabd
okay perfect i will let you know thanks a lot man
saltchuckmatt
Well there is the pee stream. That says the pump is pumping. But that doesn't say if it's flowing around the engine. (Thermostat failure or passage ways plugged.) If you have a thermal gun (fairly cheap) you can shoot the heads when warm. Looking for 130 or so. Still think it's the fuel system but all the other things still need to be tested. Hope this helps.
gabd
its defenitly helping me a lot
and when you said fuel system you mean tank , line . filter and pump
right ??
gabd
im 100% sure the pee stream was on but i will check thermostat
saltchuckmatt
thank you so muchim near vancouver in british columbia
And by the way, because I'm not aware of your boating knowledge, you did make sure you have oil in the reservoir? Because if your alarm is malfunctioning and no oil......
(No disrespect intended) Also, you can just check for spark you have to check for GOOD spark. That means a tester that measures how far the spark jumps. Again, if you didn't do anything reckless, and those tests check out....old dirty or water contaminated fuel or the vro needs help.
