- Jul 18, 2011
- 19,016
Here are some pictures and other information to help address some of the questions.
Controls and gauges/displays . . .
FireBoy/Halon . . . just the light. Not sure if they are connected or not.
Looks like there is a purposeful feed to the DTS . . . I still have to trace it out.
I found this for the Axius . .
I exercised this 'clean pwr' CB . . . it looks like it has been replaced as it is different that the OEM CB's.
The joystick does work . . . probably needs some calibration, as the boat likes to go backwards sometimes when it should be rotating.
I have posted the Diacom results from the starboard engine several times, and have only posted the port engine once or twice. I'll see about getting the latest starboard engine screenshots and re-post them.
The engines are about 50% hit or miss as to the voltage warning. I got the warning a couple of times today, but several other times the engines said OK.
The inverter was factory installed (Standard equipment) as per the build sheet below.
