Mercury Black Max XR2 150
ronnie@69
I'm new to the boating world trying to get a little help there's not much info on you tube being this motor was made in 86 or 87..was wondering how the out board recharges the dual batteries and the ratings on this old guy..it does run and starts fine
Depending on the year, that motor has a single 40A voltage regulator, twin 20Amp voltage regulators, or a rectifier and unregulated charging system. A 1987 Merc 150XR2 looks to have the rectifier. Newer motors have the VRs. Not sure of the charging capacity of the '87, but expect to be no more than 10Amps.
Magnets in the flywheel spin past stator coils, producing the electricity for the VRs to rectify and regulate.
Dukedog
has tha 16 amp chargin stuff.. individual regulator and rectifier.. it seems like its jus enough ta keep up with tha main starting battery if ya runnin' very many electronics.. for years and on 90% of all tha mercs i've built/had i ran tha 16 amp stuff with jus a rectifier without any problems but always had very good battery's with good maintenance...............
Faztbullet
That motor has a 16amp charging system and only the 1991 had a water cooled 40 amp rectifier
ronnie@69
Thank you very much for the valuable information
ronnie@69
Thank you for the amp charging system information it's much appreciated
