Engine wont shut off with key
kenny nunez
On the ignition switch remove the wires that go to the gauges, one of them is the one that is feeding back to the ignition switch. Whichever one has 12volts is where you start tracing to find the source.
Jakem
I removed the green and no power at wire...power at post...there's a little spark everytime I touch the terminal as well
alldodge
That's what I'm saying, the power is coming from the solenoid. The slight spark is normal because it powers the motor back up, same as turning key ON
Figure you have a multi meter. Check for a connection between I and the right side post on the old solenoid. If there is a connection and the old worked, it has to be cables. If there is no connection, then the solenoid is wired internally different
nola mike
Even with key out my choke element does its thing
Does it do that with the green/tan wire disconnected?
Edit: ok,
1. Disconnect green wire at solenoid. Does engine start/run? If so, your problem is not with the solenoid.
2. Disconnect resistance wire at the coil, reconnect green wire. Engine should want to start but die when you let go of the key (go from start to run). If it continues to run you have a problem with the solenoid or wiring at the helm/ignition switch
Jakem
I will check all these...it worked fine for about 4 starts and was shutting off normal with key....and then the next time I tried...no off..
alldodge
That would have been real helpful to know up front
Put the old one back on
Jakem
Alright...fired boat up...pulled green wire and it stayed running....I shut it down and left green wire off...boat starts and shuts off with key without I terminal hooked up...the voltage at coil positive is sporadic jumping around. Now I'm really confused
alldodge
When running the voltage powering the coil goes thru a resistor which "should" drop the voltage down to around 9V. There is probably a weak connection in the key switch so voltage jumps around.
It will start without full voltage (green wire) but will have a harder time doing so mostly when cold.
Jakem
Alright so then if that's all normal why will it not shut off with green attached...
alldodge
I'm not being flipped, and I am sorry that I've been unable to explain what is happening. Maybe someone else can
alldodge
Old guy old term, Be angry, ecstatic, holler , frustrated
I'm not being that, I just don't know how to explain what's happening and why any further. I could put it all on one page if that may help, just think another might do better
Jakem
Well I appreciate your efforts for sure. Electrical baffles me so I apologize for being a block head lol
flashback
You got a lot of help, I understand frustration, but some how your ignition is being fed when the key is off. How are you shutting it down when running?
Jakem
Pulled the wire that comes from 40 amp breaker to batt
alldodge
Motor has 2 different means to power the coil
Key in ON/RUN sends 12V thru resistor directly to the coil. Reaches coil with around 9V
Key turned to Start sends 12V to starter solenoid. Solenoid energizes and connects power to starter and also sends full 12V bypassing the resistor (Green wire) to coil for stronger spark
A solenoid is like a switch. The key switch turns the solenoid ON or flips a switch next to starter. Think of it as when it energizes the switch connects battery power to the starter and to the coil because “both” wires are connected together inside the solenoid.
Since you get 12V on the small post full time no matter if the key is ON or OFF, this means the switch connection “inside” the solenoid is still connected. The I terminal and the large starter post terminal on the solenoid are connected together inside the solenoid.
Take the old solenoid, put meter on ohms scale and connect it from the right side large terminal and the small I terminal on the right side. If there is a connection (low resistance value), then the large battery and starter cables need to be swapped to make it work correctly. If there is no connection, then the old is not the same as the new one
kenny nunez
I hope you have a 12 volt test light. That is one of the best tools for quickly finding electrical problems. That will help you find where the current is coming from.
Jakem
Here's the thing...I hooked old soliniod back up and wires the way they have been since I bought the boat...fired up...runs smooth...and shuts off with the key
