BWR1953
- Jan 23, 2009
- 6,530
On 1 Jun 22 I was on a fishing trip. The engine ran normally at startup, then cruised to the first fishing hole at 5,300 RPM WOT like it usually does. When we slowed down, the engine didn't sound right. It burbled and gurgled and made the 2-stroke ring-ding-ding sound. Hadn't heard that before. My boy even noticed and said "That doesn't sound right." as we were slowing.
We fished awhile, then got ready to move to a second spot. The engine fired right up but wouldn't accelerate normally. It barely got to 3,000 RPM and if I pushed the throttle more, the engine would bog down further. So, I just limped us back to the dock as quickly as I could get us there. I didn't do any testing, like squeezing the fuel bulb. I just wanted us to get to shore quickly.
Engine info:
1985 50 HP 4 cylinder.
S/N 6589696
Power trim & tilt
Walbro carbs
We've done a little troubleshooting and it's looking like a fuel starvation issue. Maybe? I'm not real good at troubleshooting. And I'm concerned about compression as well.
Background:
In May, we went on a fishing trip and at the dock when I squeezed the fuel primer bulb, gasoline started squirting out of the side of the bulb. Trip over!
When I replaced the bulb in May, the fuel hose ended up being short, so I just connected it up the way it was and that's how it was rigged during the issue on 1Jun22. We replaced the short section with a new 3' section last week.
During testing, the engine fired right up and idled fine. Telltale was normal.
The carb fuel filter was inspected and no debris was found and was full of gas when primed and the engine was off, but had low fuel level while running.
We completely drained and filtered the gas can and there weren't any major issues there. Just one bitsy little item.
The in-tank screen had a little bitty hole, but that was it.
Engine info:
S/N 6589696
Power trim & tilt
Walbro carbs
Background:
