nola mike
- Apr 22, 2009
- 5,962
I've had this thing for 7ish years? It doesn't get the attention of the other boat, and rarely needs it. Last season noticed that shifting into/out of gears was becoming difficult. This season (after it got hammered in a storm at the end of last season) it's much harder, particularly getting into fwd. No grinding or anything. The cable moves freely. Putting a wrench on the horizontal shift shaft is easier, but seems still harder than it should be. I'm trying to find everything that can be lubricated. Manual isn't much help (not sure if I'm using the right one). I can't find a good diagram of how the shift lever connects to the lower unit shift shaft, I'm guessing that that's where I need to start. #10 in the attached diagram I think. Not sure how to access it or if there's other things I should be looking at. Nothing before the horizontal shaft feels too tight. Once I get this going I'm going to have questions on setting up the timing sync. I'm not near the boat or the serial#...
