nola mike
- Apr 22, 2009
- 6,045
Unless you go with vortec heads? You have a Gen II block? If so that means it has a balance shaft, so the timing cover and water pump WILL go over to the new block.
Most likely yes.
As Scott said, the newer blocks use an unholy combination of metric and imperial fasteners. Your starter won't swap over because of this either.
You need to decide if you were going to use vortec heads and a four barrel carb or not. The swap will be a good bit simpler with your current heads and carb. But not nearly as cool.
