gohawks688
Thread starter- Joined
- Jun 8, 2015
- 70
Took the boat out for a test run yesterday and it would not rev above 2k rpm or plane out. It started fine and didn’t seem to stumble or hesitate.
I have recently done some work on the motor….
Deleted oil system and switched to premix gas. Oiling system shouldn’t have an effect on max RPM. Neither should deletion of oil system warning module.
New impeller and gear oil. I don’t think it is possible to put the lower on with the gear position reversed. Boat shifts fine into all gears.
Fuel should be in decent shape. Full tank in September non ethanol with stabil.
I verified butterflies are opening fully and linkage has no binds.
All three carbs were rebuilt last year.
Here is my list of things to verify in order of likelihood/ease.
Any thoughts guys?
- Verify no air leaks in fuel line. I had to reconfigure lines when deleting oil system. Fuel could be restricted or have air leaks.
- Check anti siphon valve. could be restricting flow.
- Spark test.
- Verify timing.
- Fuel pump rebuild.
- Ignition tests (switch box, stator and trigger per manual) I have a DVA adapter.
Any thoughts guys?
