Starting Issue
banchigu
Good Afternoon everyone, I have a 1978 85 H.P. Evinrude engine in immaculate shape with 120 on all cylinders, timing is set, and it runs really good.
The only issue I have is that on cold starts or if I run it and let it sit for more than one hour, I have to give it a shot of ether to get it going, not a big shot just an indirect shot into the air intakes and it fires up like a dry Texas grass fire and idles like a purring kitten.
I think it may be a choke issue, because I have fuel in the bowls (I just overhauled the carbs).
A million thanks in advance.
Seeker10
I have the same motor ,mine was doing fine .then all of sudden it will only run on the starting fluid .like it doesn't get the gas coming to it .and I know the fuel and tank are clean and fresh
