Jstorres486
Thread starter- Joined
- Jun 4, 2022
- 9
Hi guys I’m new here just trying to see if I can get a little help… I have a 1990 suzuki dt30c.. I have submerged whole lower unit in 55 gallon pail when I start the engine it pee out the pee hole but after about 20 seconds it’s starts spluttering water and then it completely stops and only hot air comes out the pee hole… any idea what it can be? I changed the impeller,plate and gasket and nothing.. I sprayed water up the water tube that connects to the impeller pump and water comes out perfect… I also turned the motor on with the thermostat off and water will gush out perfect from pee hole and thermostat housing. I kinda feel exhaust coming out the thermostat area while the water is coming out don’t know if that’s normal… once I put the thermostat back in the pee hole stops squirting and air starts to blow out again.. I tried it with just the thermostat cover and no thermostat and same result… idk what could be wrong… any help would be appreciated thank you!
