- Mar 8, 2009
- 44,086
Ya need the same tool to remove/install the hose on the bell housing sideHmmm ok….looks like I’ll just leave the dang thing in then.
You can remove the fitting without the special tool, it's just a socket that has four tabs on the O.D. to engage the splined portion of the insert. By the looks of the corrosion and buildup of crud even if you had the special tool most likely you'd be replacing the insert. Kinda funny how you got the bell housing side off but now you feel this is too much?Hmmm ok….looks like I’ll just leave the dang thing in then.
Bravo does not have a impeller in the drive, only one on starboard side.Hmmmm ok, I just thought about something. When I first bought this boat it had the bravo 1 drive on it, doesn’t the 1have an impeller located in the drive itself? The reason I’m asking is because I’m pretty sure it also had the impeller located on the starboard lower side of the engine .
Sure with drive removed, just connect hose to input bell housing connection.Hmmm ok that’s what I thought. Has anyone ever hooked up a hose directly to the pump instead of trying to use the muffs?
I think that’s what I’m gonna try to do when I drop the motir in her to get her up & running…I hate them damn muffs….Suse, with
Or remove belt to pump and connect hose to input connection at thermostat housing
Ayuh,..... It's a false economy,....Another question, pertaining to the bellows, has anybody on here ever ordered and installed the Bellows that aren’t so darn expensive? I mean I know the quicksilver Bellows kids are over $400, when you can get bellows kits on Amazon or eBay for right around 60 or 70
Have you ever ran any of them cheaper ones?Ayuh,..... It's a false economy,....
I've run Sierra, 'n won't again,.....
Not worth it, go oem for bellows, impellers and electrical componentsHave you ever ran any of them cheaper ones?
Not on your life. Mercruiser for anything rubber.Have you ever ran any of them cheaper ones?
I ran a cheaper water pump impeller lasted about half as long as the oem impeller before engine temp started creeping upHave you ever ran any of them cheaper ones?
Are they the sierra kit?I'm in the minority having run Sierra rubber bits without issue. Seems something else always breaks first, and I'm replacing the rubber before it wears out anyways. Last bellows are 4 years in and look brand new
