out drive
brian3127
i need to buy a new gasket set for my outdrive.
the serial number in the picture of the outdrive
is that enough information to order the right one
Scott06
That's the transom housing serial number the outdrive serial is located by the vent plug on the upper housing- just below it. It will be not only in the sticker but also stamped in the metal is the sticker is gone or damaged.
brian3127
ok thanks guys.
1 more question. most people on here says to pull the drive every year to do Maint. i took my outdrive off last year because we pulled the motor to have it rebuilt.
does that mean you put new bell house gasket and o-rings every time or are they reusable
brian3127
new gaskets and o-rings
I couldn’t find the serial number on the outdrive above the vent hole.
It says alpha 1 though.
Would this be the alignment tool I need also
