1959 Evinrude Fat Boy 50hp
Mgman71
Hi group. I have a 1959 Evinrude Fat Boy 50 Hp engine. Is there a way I can put a Tach on the engine ? Thanks in advance.
jimmbo
Yes, Tachs were used on Magneto Ignitions for Decades
jimmbo
Here is a link to a 3rd Party Service Manual(one of the Better ones), it is a PDF, so it can be downloaded.
You might have to resort to using an Inductive Tachometer. If you feel you need one to pick a prop, not to worry there are only two Props available for that engine, initially it was a 13 x 13, and later it was a 12 1/8 x14, both tend to yield similar rpms
A smooth running / powerful motor.-----But the reputation of an inefficient user of fuel.-----I can identify one by the smell off the exhaust !!
jimmbo
1/3 the fuel was burned, 1/3 was pushed out the Exhaust, and the last 1/3 was dumped via the Crankcase Purge Valves
Mgman71
There is a coil inside the magneto !!
I will check it tomorrow. Thanks
i have owned this motor for 10 years have not noticed that much gas used… will what this year. Still would like to hook up the tach. Hope someone can help. Thanks
jimmbo
I have searching the Various sites with Documents on old Motors but haven't come up with anything. I would think one of the M terminals on the Ignition Switch, would be where a tach would be hooked up, but I am not going to say to do that just yet.
In my 1977 OMC Accessory Book, it shows two Tachs for Magneto Outboards, also useable on the 4 Stroke I/O's of the day.
Part # 172077 and #172926. So maybe an Automotive tach might work.
Mgman71
Thank you for looking around. If you see any other info please let me know.
