Engine backfires around 2500 rpm
Sarnia
Engine backfires around 2500 rpm and sometimes when you first takeoff
any suggestions (2001 4.3 litre mercruiser)
thankyou
Ok thanks will start checking above, appreciate the reply
Ayuh,.... Welcome Aboard,...... Check the Contents of the fuel filter, for anything but clean fresh gasoline,.....
Don't just pull it, 'n toss it,......
You'll miss a Great diagnostic point,....
alldodge
Either way its a fuel issue and most likely a carb problem. Backfire at 2500 is lean so carb not supplying enough fuel. Causes; dirty carb, weak fuel pump, antisiphone valve
Backfire on take off is lean fuel. Causes; dirty carb, carb accelerator pump
jimmbo
Could also be a crossfire from Spark Plug Wires or Distributor Cap. Acceleration increases the Voltage required to fire the Plug and Electricity doesn't where it goes, as long as it can complete the Circuit.
Sarnia
I have a 2001 4.3. Was doing same thing , replaced wires, filters, s plugs, coil, was still backfiring , turned out to be faulty thermostat changed it and boat runs like a top.
