Water inside Mercruiser gimbal housing
liusigou
Today I removed my outdriver and found some water inside. Also there is more and more water inside the boat during boating and I have installed a automatic pump to deal with water. What issue for my outdrive? How can I fix it?
See attached
nola mike
Several potential spots, but first to check is your bellows. When was the last time they were changed? At this point your gimbal bearing looks rusty, so u joints are probably shot too. Also need to check your outdrive oil for water, input shaft seal may be gone, along with drive shaft damage... All needs to be addressed before you get back on the water. Using a bilge pump with a known leak in an unknown location is a very, very bad idea.
liusigou
Is the bellow house damaged?
I will try the cheapest one. Just buy gasket and water passage o-ring and to mount my new used outdriv. if there is not water any more, it is great.
nola mike
What? No, no to all of that.
achris
More fish than mountain goat
That's what you have to determine. We can't see that fromt he photo. You need to turn the steering all the way one way and then look and feel the bellows (looking for hole, splits, wear or damage), then turn the other way and check the other side. Also don't forget to check the bottom. But only you can do that.
The cheapest bellows and other parts are about the WORST thing you can put on. They are more difficult and don't last very long. I HATE Merc (personal reasons), but their rubber parts are the best... By a long way.
Chris.....
Bt Doctur
I dont see the large rubber ring that is usually glued in first and the gimbal bearing needs to be replaced
achris
If it were mine, I'd be replacing bellows, gimbal bearing, unis and shift cable (you can see water has been laying in the slide cavity). I'd probably take the bell housing off completely and give it a thorough clean. I'd also be taking the yoke out of the drive and disassembling the seal and bearing pack as I suspect the seal surface on the yoke is rusted to hell and back. It'd be a new yoke or a speedi-sleeve. And at that point I'd be inspecting the drive gear bearing pack bearings, with a view to putting new ones in.
But that's me and I understand how sh1t should be repaired.
Chris.....
Rick Stephens
Chris.....
So OP has already said he intends to stick a gasket on it and just slap a different drive on. So his/her list is a little shorter since hopefully the replacement drive is sealed up and u-joints are good. - There is certainly a lot more than only a gasket and an o-ring needs doing before it just gets even more expensive. But up to the PO.
achris
I find it 'interesting' that people come to these forums for advice, then complete ignore it and do what they were going to do anyway. Seems a waste of (everybody's) time to me...
Chris.
nola mike
Chris.
Yes, my post #4 was trying to figure out how he got to #3 from post #2 😄
Benny67
Chris.
i believe he was just asking a few questions. Although he's clearly not fully understanding the problem he is having, it's not your call to pass judgment.
if you feel its a waste of your time, just ignore the topic.
achris
As Don once said,
Never time to do it right, but always time to do it again.
I would add "also spending more money to make it right the first time"
I've always said the quickest and cheapest way to do a job is to take your time and do it right the first time...
