Evinrude 90HP Ocean Pro
MasonK
Hey guys, I was hoping someone here can help me! I purchased a used boat with a Evinrude 90HP Ocean Pro E90SLEDR. I replaced the water pump and my shift rod got out of alignment.
I’ve been searching all over the internet for the correct height. But I can only find generic information on 90hp Johnson and Evinrude. I can’t find the correct height for this particular model. I’ve seen anything from 22-1/8, 22-1/4 and even 22-7/8.
This morning at 22 1/4 I could only go into neutral after going into reverse, and barely into forward. I tried to get to 22 1/8 but can’t get the pin to lock into the shift rod at that height, have clearance issue from the carburetor being in the way.
Anyone know what the proper shift rod height is for this particular model?
Why would you be hesitant to set it at 21-1/4"----Any pictures of your lower unit ?----Are you 100 % sure it is the correct shift rod for the V-4 looper 60 degree ?
