Old merc outboard details?
paquette.kaden
Hi all. I have a mercury 200, 20hp outboard. I can’t find any info on the serial number, can someone find me the year and a repair manual?Canadian Serial number is 7077796. The rest of the data plate is wore off, those are the only stamped numbers. Thanks. Also, if there’s a parts break down that would be good too. Spun the prop and leaked all the foot oil out.
Sounds like a Canadian built 1976 model.-----Decal stripes look like a hockey stick ??
paquette.kaden
I should add too, is there a way to cross this to an American serial number in order to get parts?
As I thought on the decals.-----Your location ??-----Easy to find parts listing online for both Canadian and US models.---
paquette.kaden
I guess I will have to do some more google research for better Canadian parts websites. Thank you for the help!
Do you not have a local Mercury dealer ?----Most will help you with your search for parts.-----Your location ?-----Maybe I can suggest a dealer near you !
paquette.kaden
I’m in northern Ontario Canada. I have a local dealer, I just assumed they wouldn’t really be able to help because of the age. But I will give them a shout next week.
Most repair shops in small towns have disappeared.----Support them while you still can.----Give them your serial # and in a small town they should help you !!-----Northern Ontario is fairly big.-----Takes me 2 days solid driving to get to Manitoba from my place.
paquette.kaden
Yea it is pretty big. I’m in Sudbury.
Snookie71
Hi... I have a 80hp Mercury blue line but the serial number is Mariner and I can't find anything about it anywhere. 9412359 is the serial number.. Can some one help
Snookie71
Those decals were used in the 81 / 82 model years.----Why do you say it is a Mariner serial number?
Your location ?----Motor marketed in Europe ?-----Found on the list of Belgium produced Mercury motors ?
Snookie71
ZIMBABWE Africa.... Made in the USA but still I can't find any specs about it... Going in a few hours testing props and I think the prop I was given is to big... 17 pitch just looks huge.
This motor uses the same pistons / rings / rods as the 2 cylinder 40 HP , 3 cylinder 65 HP and 6 cylinder 115 HP.-----About 66 cubic inches (1100 CC ) displacement.----What specs are you looking for?
Snookie71
OK that's helpful thank you... Its a 4 cylinder and I can't find any info on the block...
