Where can I find this connector?
jeremyjohnolson
Can anyone tell me where I can buy this connector or what it is called? It is on a 2004 Tige boat. The handwritten number on it means nothing, I just wrote that on it myself to know which connector goes to which.
call Tige's customer service line and ask
Scott06
pin size may not be the same also Mcmaster carr carries some Molex connectors biggest went up to 12 but they can likely order it
Scott06
Cheap plastic junk.
Pins are junk
Find a supplier for the real thing. We use Mouser but there are others
The link I sent on amazon is from the same supplier Molex that you linked to... seller is the Molex Store
dingbat
Same supplier, not the same part.
The one on Amazon is one of those cheap plastic housing with the stamped out pins. Decent ones use crimp pins
vroom ZOOM
Well, ain't you lucky, I found it for you... 2 bucks... have a browse through the list and see which exact one you need. Seems like it is a TE universal MATE-N-LOCK plug.
make sure you get the exact same lock combination. (D shaped pins vs round)
