Alpha one gen 1 reverse not working
Clarko1988
Alpha one gen 1 my reverse will not engauge unless i pull the shift cable hard. forward works fine when pushing in.
achris
More fish than mountain goat
Did you check for excess 'slop' in the cable system? (one of the first things in the video). If the shoe (between upper and lower housing) is splayed slightly, or the grub screw in the end of the shift slide isn't set EXACTLY right, or the roller on the upper shift shaft lever is worn.... You get the idea. You have to eliminate all the places where excess movement can be introduced. That is what you problem sounds like.
Bt Doctur
When you install a new cable you cannot leave more than 2 threads showing
Clarko1988
Soo on the upper shoe is there suppose to be a small amout of play where the lower shoe meets the upper shoe?
achris
Define 'small'... (When I'm setting them up, I shoot for zero)...
Clarko1988
Pretty sure i found the problem looks to ve that the slider doea not pull back far enough
Think I'd pull the drive off and have a look at the cable area (where the cable is screwed into the bellhousing) for build up/crud keeping the cable from being pulled back far enough..
Clarko1988
Got another question to remove after removing bearing carrier will thw prop shaft come right out or do i need more special tools
achris
You need to remove the pinion gear before the propshaft will come out. And you need a special tool to remove the pinion nut.
Clarko1988
Ive been trying ro find a video how its done but i cannot find anything
achris
Forget videos, go by the factory service manual. Most people doing videos are not Merc trained technicians. And some of the videos I have watch left me SMH.....
Chris.....
Bt Doctur
Heres a better question . Why are you taking things apart without the manual BEFORE you know what is wrong?????????????????????
