Lou C
- Nov 10, 2002
- 14,323
That’s the style I’m referring to; the bracket bolts onto that pad where the spring used to sit. There is another style that can be used on Vortec engines where there is no choke coil mounting area. The Vortec engines do not have the exhaust cross over so they all have to use electric chokes. If you are using a Holley or Edelbrock you have to use an electric choke but if using a Quadrajet you can leave it with the hot air choke. Which carb are you using?
