Striperhiker
Thread starter- Joined
- Nov 4, 2021
- 2
I have an 18 ft Dixie Runabout w/ a 90 horse mercury. 1978. My question is how big is the gas tank? Yes it runs great. HELP!
Thank you for the info and suggestion. Going to add staybil for the winter. I think it’s one ounce for every ten gallons. Is that correct?The tank should be marked with capacity. An 18 footer of that vintage will have a 30-35 gal tank, I would think.
Why not fill a 6 gal tank, and run the main tank dry, come home on the remote tank and see what it takes to fill it.
Stabil should have the proportions on the label. I believe Marine Stabil (the blue variety) has a different mix than the red variety. I always just go by what the label says, then add a bit more.Thank you for the info and suggestion. Going to add staybil for the winter. I think it’s one ounce for every ten gallons. Is that correct?
I had a 1972 18' Caravelle tri-hull with an 18 gallon tank if that helps.I have an 18 ft Dixie Runabout w/ a 90 horse mercury. 1978. My question is how big is the gas tank? Yes it runs great. HELP!
