newtoboat101
- Jul 9, 2015
- 412
What type of coating was already on the upper?? Did you sand and prep for painting?? Paint will peel when applied to a surface that is not properly prepared for painting including temp of the paint,surface to be painted and ambient temp etc.Charlieduring winter i re painted my upper outdrive,put boat in my slip on lake ontario ,when i pulled out last week after being in water all summer ,my upper unit looked like this all paint gone ,,whats going on here ,i used merc outdrive primer and paint on upper unit and skeg,, felt outdrive paint would be fine ,also i added a mercathode over winter ,if that means anything, this is paint i used
Mercury/Quicksilver Parts Paint Phantom Black 92-802878Q 1
I thought SEI was plastic or composite and not aluminum..?? CharlieDarn, that's terrible!
Could it have anything to do with it being an SEI and not a Mercruiser drive? Aluminum is aluminum, so I wouldn't think that would matter.
Awaiting for the experts to chime in...
Only way to know is repaint. Then with boat back at the dock plugged in for at least 24 hours and measure the output voltage with the correct probe.thanx for replies ,i guess we can assume that its not a mercathode,,electrosis or anything like that ,and just bad paint job or paint used ,or maybe temp ,nothing crazy ,correct
