Bent blade tip - not sure what to do
todhunter
Canoeist
I'm new to boating and bought my first boat a year ago and have been working on a full gut and restore. It is a 1987 Power Play XLT-185...an 18.5 ft closed bow sterndrive with a Mercruiser 5.7 / 260 HP and Alpha One Gen 1 outdrive.
I purchased a used stainless steel Quicksilver Cleaver 21P / 14.75" diameter prop on FB marketplace. It is a 3-blade prop and has part number 48-89802 A5. The seller did not pack the prop very well and now one of the blade tips is slightly bent - not 100% sure if this was pre-existing or happened in shipping at this point. I asked if there were any nicks or dings before buying and he said no.
Here is a picture of the blade. My question for you guys is should I just run this as-is? Is this OK for a used prop listed as "good condition"? Or, am I going to run into vibrations, unbalance, or something that can damage my drive? Should I get this fixed by a prop shop, and if so, any clue as to how much that would cost? Appreciate any help you can give this boating newbie.
Here's a picture from the ad:
Here's a picture of the bent blade tip:
robert graham
I doubt it will give you a problem but maybe take it to a prop shop for their recommendations, straightening, balancing….if required
Have a prop shop straighten it.
That is a high performance prop. Normally used for production "racing" boats. Not one I would normally expect on a boat like yours. If you do not get good performance, that could be the cause.
Ayuh,...... Most prop shops oughta fix that for 'bout $100......
Cleaver props like that give good stern lift,.....
A chopper will give better bow lift,....
todhunter
Canoeist
Thanks Bondo. I dropped it off at a local shop on Friday. There were some other issues like small dings and rolling of the leading edge in a few spots. He said it would be about $180 to have it fixed up completely. Hoping to pick it back up this Friday.
todhunter
Canoeist
Thanks for the reply. This is the prop that several of the folks with XLT-185's recommend using, so we will see. I did end up taking it to be fixed.
