2001 Mercury 25hp POWERHEAD
Aneddeau25
I have a 2001 Mercury 25hp that has low compression in the bottom cylinder. What are my best options? Where could I find someone to rebuild it or a used POWERHEAD?
Your location ?-----Getting hard to find shops that will rebuild these motors.
Aneddeau25
Maine, I found a used powerhead but not sure if it will work, it’s not a mercosil block but the guy said it will fit a 25 Mercury. Has very similar part number.
Aneddeau25
This is the used one for sale. And my part number is 872-9076-c14
flyingscott
Rebuild it yourself. The kits and the manual are available. The hard part might be finding a shop that can do a blind Mercosil Bore.
Aneddeau25
I just may have to but the kit is 400$ and so is the powerhead I found it looks like it will match up. Just the last numbers has me a bit worried.
Faztbullet
That used one is a chrome bore and they scuff as bad a s the Merosil block. Make sure seller guarantees compression and sends you pics of cylinder walls
Very easy to remove bypass covers to inspect condition of motor.
