Top Secret files
bocephus1369
Just curious what happened to the top secret files? They all redirect to something completely different. Are they even more top secret now?
GA_Boater
All of us have the same problem because some links were broken during the installation of new forum software last year. Re-linking has been slow.
@GA_Boater , will try to list most of the links I can find here
for the ethanol fuel line and carbs, it will be one of these https://www.google.com/search?q=ETHANOL,+FUEL+LINES+and+CARBS+site:iboats.com
boat sitting for two years will be one of these https://www.google.com/search?q=IT+HAS+BEEN+SITTING+2+YEARS,+WHAT+TO+DO?+site:iboats.com
primer solenoid
points and coils
starter will not engage
Manuals and diagrams
@GA_Boater ....more
changing oil may be one of these
compression test
removing flywheel may be one of these
installing cables
winterizing may be one of these
lower unit interchange
cold start proceedure
what year is my
pressure and non pressure tanks should be in here
VRO conversion should be in here https://www.google.com/search?q=VRO+conversion+questions+johnson+site:iboats.com
to all of the members that want to help with the relinking portion.
it takes time
also, it requires taking the headlines from the stickies and pasting into google as such Maintainance schedule johnson site:iboats.com
I added the word johnson after what I was looking for to further narrow down some search parameters.
this site gives us all so much, least we can do is help dig up the threads so @GA_Boater , @jbcurt00 and the staff can re-attach and rebuild the stickies
GA_Boater
Thanks, Scott.
If the TS link has Verified at the end of the link, it should be a valid link.
BTW - Broken links are all over, not just in
the Top Secret Files.
