Can’t find dropped pin
Bob&Jill
Sadly I dropped one of the pins while removing the steering actuator and searched for hours but couldn’t locate. Could have possibly deflected into the gimbal housing from engine compartment opening and if so what to do now? It’s a Volvo penta 4.3 with SX outdrive.
kenny nunez
If you are looking for the stainless steel pin that is held in place with a cotter pin you can use a 3/8” stainless bolt with a self locking nut.
Bob&Jill
Thanks, I’ll probably have to do that. My biggest concern is if the pin fell into the gimbal cavity in the transom will it cause an issue?
kenny nunez
You will probably find the pin in the bilge after the boat runs on plane for a little while.
If it was to get into the flywheel housing that would be a problem. Not very likely to happen however.
Bob&Jill
Thanks, definitely hope it shows up later. Just sent the actuator to be rebuilt today so when it’s back and installed maybe I can shake it loose!
dypcdiver
Use your phone camera to take pictures where you cannot see or get your head into places.
