Larry Baloun
Thread starter- Joined
- Jul 28, 2017
- 34
Engine runs smooth and performs well. Idle set at approximately 650 rpm. Serial # 1A312851.
Diesels badly nearly every shut down with regular fuel. Still diesels with premium fuel, but not as bad.
I noticed there is a vacuum hose fitting coming off the distributor ... but no hose attached. I assume this fitting is not there for decoration, could this be the problem?. If there should be a hose attached, where does it go to?
If this is not the problem, what else should I look for?
