Does Johnson sail have different gear ratio?
Joost0
Hello,
I have bought a johnson 8hp 2stroke outboard with mod number: J8SRLEIA. This happens to be a sail outboard so i am worried That it has a different gear ratio so it would be slower. I got it on a 4 meter boat. Does anybody know more information about this?
No-----Same gear ratio as a regular motor.--And a " sail " motor would be for a 20" or 25" transom.-----What transom is on your boat ? -----A heavy slow boat would use a different prop.
Joost0
My transom is around 17" and i noticed the prop is rather different than other props is see. Is it possible to change the prop?
Joost0
My transom is around 17" and i noticed the prop is rather different than other props is see. Is it possible to change the prop? The shaft is 20"
Yes it is easy to change the prop.-------But hurry to your local boat shop for help on selecting a prop for your boat !
