frustratedboater
Thread starter- Joined
- Jul 10, 2007
- 506
My 150hp Honda has a steady alarm at about 3-4min at idle. I did notice white scale flakes coming out and an intermittent stream and had to keep clearing it.. I did get mix communication that the motor may have sat a few seasons when I purchased it.
I pulled the unit off to check the impeller and the pump looks new, the water pickup flows out through the bottom of the pump plate and no visible clogs. The T-Stats look new (ish) and had no crud in or around them and I boil-water tested them and they both opened. I did force water through the thermostat housing and out came more scale out the pickup tube. I also ran water up that pickup tube in 15 sec. shots and let it drain out and got a little more of that scale stuff. I did this 6-8 times..
I ran it and alarm sounded at about the same length of time. I disconnected the T-stat housing, removed the stats and started the motor to see if I'd see any water out the T-stat housing (lg. blk hose) for 15 sec and did not. I did not see water running up the T-stat holes aw well and thought I'd see something. I re-assembled, then scratched my head.. Is there a passageway crud could collect restricting flow I'm missing?
