Lou C
- Nov 10, 2002
- 14,522
The wood is underneath all the fancy upholstery and wrap etc. Fiberglass itself is not that rigid. To make it rigid, you have the hull reinforced with stringers (like floor joists in a house) that run front to rear, the transom is cored with 2 layers of plywood, the deck is all plywood on top of the stringers. This is all glassed in with polyester resin, and fiberglass math/cloth depending on the builder. So if they covered the deck with carpet, and drilled holes to mount seats, and did not seal those holes, the rot will start when the temp and moisture are right for it and spread under that fancy interior. Then one day you hear the crunch. Or the 'glass round the motor mounts starts to crack, or cracks appear around the transom, or it starts leaking. It is VERY difficult to check for rot in a boat like that which was obviously re-done. And rot repair, is way worse than replacing an engine or an outdrive, it is messy, toxic, time consuming, horrible work. That's why I say never again. Only 2-5 year old boats for me and only outboards. No more rot repairs, no more standing on my head, none of it. Ever. Again.Hello! Thank you for the reply, no worries about being abrupt I totally get it and that kid must of been a JackA$&.. I would never do that. And unless I’m alone in a very big body of water I would never even think about making a wake like that.
I appreciate the wisdom.
At 26, I’m a Licensed bodyman now going for my second license as a licensed mechanic. I own my own house. Soon to be an income property and purchasing another home with a nice fancy garage lol.. And two vehicles upwards of $70k both paid off. I’m just trying to say I’ve been saving. I’m very good with saving and finances. I don’t own a payment.. on anything! I have taken the boaters course. I’m very aware of the dangers. I’m not a young punk. Nor do I want “chicks” i’m in a commited relationship and this would be for her if anything. I want a boat of this magnitude this as it’s just what I have been saving and dreamt about for a while.
As all of my friends up here have fountains and scarabs etc..
now talking about the wood. Where is this wood everyone is speaking of? Just the transom? And how can I check it. And what if it is good? Is it possible that it could be good after all these years?
I looked ALL over last night. I can NOT find a single 454 boat at least even 20’ for under 20k that’s not an 88 or older. It’s crazy! Ontario is slim pickings.
Thank you all!
Here are som pix from 2006-2007.
BTW, in 2005 when I noticed how bad the rot was getting my next door neighbor bought a Key West 2020 dual console with a Yamaha F150. This is an all composite boat, it still looks like new, and has been no trouble at all. That's what you should have! You want a V8 hot rod then buy one. Those old go fast wood cored boats are nothing but trouble. Unless you want to add fiberglass work to your areas of skills, trust me its not that much fun.
