Down motor
Balawson41
I have a 1985 20hp evinrude 2 stroke has fire but won’t start period sprayed starter fluid in cylinders won’t even hit checked compression top cylinder reads 95psi and second cylinder reads 98psi what could be the reason it won’t start plugs have been changed and gapped 0.30
If sheared install a factory replacement key.-----Install with tapers clean and dry.-----Torque to the correct value.
Balawson41
Ok thanks for the info I’ll tare in to that tomorrow really appreciate the info I’ll let ya know what I find again thanks a bundle
Ayuh,..... Welcome Aboard,..... At under 100 psi compression, it's just plain worn out,.....
Balawson41
A normal compression on a 2stroke 20hp is around 110-
Normal compression is 110-130 but seen plenty motors run perfect in the low 90’s upper 80’s but could still be the problem hoping not though lol it was running great till it just died out
Balawson41
I pulled the fly wheel and you was right sheared the key steel replacing it now let ya know if that does it by the way would you know the torque on that but I was thinking around 45 pounds
I think 45 FT-LBs is not enough.----Someone on here will have the value.--No manual handy today.
