Francisco_32
Thread starter- Joined
- Jun 28, 2021
- 11
I have a 1995 bass tracker 25hp mercury tracker 2 stroke cycle and it will crank but never start. I have cleaned the carburetor checked to see if everything was alright on which it was I did however changed the primer bulb, checked the fuel filter which was good and I also changed the Seloniod, rectifier, coils, everything is right with the CDI. Everything in the lower unit looks right which I did put in a new water pump kit. When It cranks though, I have noticed that it does want to run but won't. what could be the problem as to why it won't run?
