miscelaineous
Thread starter- Joined
- Dec 7, 2020
- 18
About 7mo ago I replace the power pack and ignition coil on my 1992 40hp Johnson 2stroke to fix I problem with it intermittently dropping a cylinder. It has run beautifully up until the other day. As I approached the dock engine began to run terribly. I put in neutral and use neutral lever to keep engine running while I pulled plug wire to see which cylinder and it was the bottom one. Change in running when I pulled that plug wire. When I returned home I changed plug wire ( switched plug wires to eliminate those). Same issue. I put everything back as it was and know engine will not start. Have spark at top cylinder but none on bottom. Please advise. Have new power pack and coil on the way. Last time this happened engine would at least crank. This time engine will not crank, just turn over. A little confused. My tools are few and crude and so is my outboard knowledge so please be patient with me. Help.
