Running problems
Paul 21655
I have a1996 Evinrude 112 spl have replaced fuel water separator new wires plugs thermostats cross flow hoses plugs .ran external fuel tank rebuilt fuel pump can't get over 5000rpm wot . Engine hard to start running rough .120 compression across all 4 cylinders.two plugs on starboard side light brown .two on port side black and wet .thinking I have either coil packs bad or cdi .any help would be appreciated.
How did it run for you last season ?----The orange wires from switch box ( powerpack ) going to the top coils are what color ?----Correct prop fitted to suit the boat ?
Paul 21655
Ran same way last year gave up after one time taking out . Original prop. This motor has never been touched by a mechanic all original parts
Paul 21655
Ran same way last year gave up after one time taking out . Original prop. This motor has never been touched by a mechanic all original parts except for what I've replaced fuel pump water pump thermostats cross flow hoses plugs and wires from coul pack to plugs
Does spark jump a gap of 7/16" on all leads on a test device ?---Compression test results are recent ?---Are you pushing the key in while cranking for the cold starting ?----- -I can not see, hear or feel your motor.-----You must do inspection / testing and report.
