2017 Evinrude
bfowler1
Hi! I just bought a 20' 2016 Manitou Oasis with a 2017 Evinrude E60DPGLAGC. I couldn't tell if it is a 2 or 4 stroke, as I was not paying as much attention as I should have. Can someone tell me what I have? Fuel mix if it's 2 stroke? I'm not really familiar with 2 stroke outboards.
Thanks!
That would be an E-TECH 2 stroke motor.-----Gas and oil are NOT mixed on this motor.------The ECU and oil injection system look after this.----See a dealer , read the owners manual before turning the key !!
bfowler1
Are you saying I just put gas in the tank like a 4 stroke?
flyingscott
there is an oil tank on that motor that will need to be filled periodically. but you should read the manual
Read and understand what you have.----Mistakes are easy to make and will be expensive.
flyingscott
one other thing to ask the owner is the oil setting. That determines which oil to use. If I was buying it I would take it to a dealer and have them set the pump as rich as possible. then run the best oil you can find XD 100
