9.9 4 stoke crankshaft
billdy
Hi I recently pulled my yamaha 9.9 4 stroke extra long leg high thrust completely down. Mainly just to check it. I did put in a stainless pivot shaft to eliminate lock down lever sticking. Now it keeps going to run on one. It might run on two for a while.
There are two things that are confusing me.
1) The crankshaft has about 10 degree play. In other words I can rotate it back and forth that much with no resistance. The fly wheel is tight. How can that be?
2) I have check all the species for the electrical, side new pugs etc. All ok except my multi meter shows .9 ohms across the input (orange and black) on the coil. The manual says it should be between .26 and .35 ohms.
PS Stripped carby and that seems fine.
99yam40
So it should be a T9.9
bad rod bearings or piston pin maybe.
have you check to see what your meter leads resistance is?
99yam40
so if it reads1.0 when touched together ,how can you measure .26 or .9 ohms
billdy
Well I am only remembering that from yesterday when at the boat so not that sure. I might head down there. Don't multometers always register no resistance when you touch the leads together?
billdy
Actually your right. One mmeter says
0.6 and other one says 1.7
billdy
billdy
On checking again it's 0.6 on one and 1.8 on other.
99yam40
yep when trying to measure small resistances always measure lead resistance and subtract it from the actual reading.
they use small flexible wire in the leads of different lengths, so no way they will be 0
