1973 starcraft 4cyl inboard
Callofmine23212
I have a starcraft I just got it new to boats but anyways I put it in to start it cranks but nothing I'm getting gas and spark starter I want to say sounds weak new battery some times it will crank then act like it's going to start but then crank again idk what is going on and I'm at a lost (I worked on cars before and this puts my head in nots) please help cheap way I got the boat for $300 so yea
What is your compression?
Did you service the points?
Did you service the fuel system?
GA_Boater
Starcraft made boats and never made any drive trains.
What motor?
Callofmine23212
The motor is mercruiser 140hp and the carb is wet so it's getting gad
And the video is with the choke on
GA_Boater
Maybe flooding like the float is stuck open or the needle valve/seat is bad.
shiloh87
No easy answer but thing to verify/inspect/test are;
-fresh gas?
-compression?
-spark/spark plug condition, when in doubt replace
-plug wires, condition?
-points and condenser condition?
-coil?
-timing?
-Gasket leaks, intake, head, exhaust?
-valve condition,(compression issues)?
-ignition lock-out, interrupter?
Generally if the above mentioned are in good nick, the engine will/should fire
No easy or cheap task, but things that need to be done, get busy..
Cheers
read this write up from the "Adults Only Sticky"
How To: Troubleshoot a Points Ignition System​
Callofmine23212
-fresh gas?
-compression?
-coil?
-timing?
Cheers
New gas, compression is good, getting spark, wires look good, don't know what points are? Coil good, timing good, no leaks, and idk how to test ignition lockout. The guy who owned it said he drove it and it was asking weak he said carb or coil bit both are working there was a time where the sparks didn't arc like they were apposed to now 3 arc out of 4
Callofmine23212
I read it but one thing I don't have light tester and they were black then I got new ones now they smell like gas so idk what it is
shiloh87
so weak spark, 3 out of 4 spark, sounds like ignition issues, which can be intermittent, just means somethings wrong or possibly failing.
Just because a coil works dosn`t mean its producing the proper potential to create a strong spark, the wires could be bad, points condenser could be pooched, distributor cap/rotor could wore out, possibly cracked?
If there`s fuel in the system, timing is good and the spark is strong you`ll get ignition, carb may not be up to snuff to keep it running, but my guess is the ignition side if you got gas and all the other stuff is good.
shiloh87
Wet plugs equal flooding, carb issues or weak ignition
Take plugs out, dry, check gap, with plugs out crank engine to clear fuel, re-install dry plugs, try it again, if you get the same results, then its most likely carb or ignition or both.
