Lou C
- Nov 10, 2002
- 14,621
Nope blown fuse means no current flow. Clicking means not enough current flow. Somewhere between the ignition switch and starter you have too much resistance from corrosion or bad terminals. Do what I advised, get down by the starter and have someone crank it while you put the voltmeter positive on the terminal for the yellow/red wire and the neg on a ground. See what you have, the hard part is you need a wiring schematic and go back and trace every connection between the stater and ignition switch. Then you'll find it.
