inAjet
Thread starter- Joined
- Oct 8, 2019
- 33
Hi All,
Replacing the factory-installed bilge pump in my 21 year-old Sea Ray bow rider. Since the new pump mounting bracket (naturally) has a different screw pattern, my original plan was to marine-tex the old holes closed and drill new ones (see attached photo).
HOWEVER... when using compressed air to clean out one of the old holes, water sprayed out the other, along with a bubbling sound below.
It appears that Sea Ray (wisely) glassed in a bilge pump mounting board (either fibreglass or wood) between the sides of the hull and gel coated it. When installing the bilge pump, and likely also the float switch, it appears they've (unwisely) used a 1-inch screw instead of a half-inch screw, which went right through the mounting board. My thinking is that over the last 2 decades, bilge water has slowly seeped into the small space between the mounting board and the hull thought these screw holes. Moving a toothpick around in these holes confirms there is a space down there.
I have confirmed with Sea Ray that the hull is not cored nor are there any screw holes into the hull in this area, so I have no concerns of core rot. The boat lives on a trailer when not in use. The question is what to do about this water. My thinking now is, instead of closing up the old holes, to just leave them open to allow for some ventilation of this space so that maybe over the course of a winter in storage the water can drain out. Maybe even drill them bigger?
Does anyone have any thoughts on what to do here? Would appreciate any and all feedback.
Cheers,
Chris
Cheers,
Chris
