nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,127
Long shot here, but I have an...over excited... friend who bought a '98 Regal with a "new" engine that ran in the driveway. It is apparently missing a "fuel pressure check valve" because the guy that replaced the engine forgot to put it in and is an "easy fix". The boat is not nearby so I can't check it out directly. Yes, everything about this conversation had me banging my head against a wall. So I do have the serial # at least, 0L2xxxxx, and I think the fuel system is original, but who knows. It comes back as a '98 5.7 EFI. Looking at the parts diagram it appears to be TBI? I don't see a check valve anywhere. I'm told that the starting procedure is turn on key, let fuel pump run, shut off, repeat and then start. Leads me to think it's a check valve somewhere in the fuel line to keep the fuel from bleeding back to the tank, but I don't see any likely suspects in the fuel filter assembly or the pump diagram. Any thoughts?
