omc cobra guy
Thread starter- Joined
- May 14, 2012
- 25
Ok im totally confused, if someone could straighten me out I would greatly appreciate it. I have a gen 2 ccw rotation out drive I have looked at all the videos available but I can't find one that really helps me. Here's the issue first when removing and installing you should be in wot forward right? Second- I had replaced the lower shift shaft and seals I watched a video on how to remove it and they said just pull it out well what they didn't say is it can go back in anyway it wants so make sure to mark it in some fashion. So I'm not sure does it turn cw to lock first gear or does it turn ccw to lock first gear? Next in adjusting shift cables do you stat in forward wot to get 6 inches and shift to reverse wot to aling the control cable ? If Criss reads this Could he do a video on ccw outdrives? thanks for any input.
