1959 johnson 50 super seahorse
AlSmithjr
I just purchased a 1959 johnson 50 super seahorse on a 1960 Akuma Mobicraft boat.
I can't find anything on the boat but the motor runs like new. Boat is in good shape as well as the trailer. $500. Investment.
Your thoughts are welcome.
Geoffrey Graydon
Sounds as if you got a good deal,might be a good idea to check the pump impeller if you don't know when it was last changed.
Those motors are unbelievably thirsty / exhaust is very smelly too.-----Yes they are a smooth runner but not really for every day use.
Those motors run very well and are very powerful at low RPM, due to the 70CU Inch displacement. They do not rev up very high, but you should see about 27MPH max speed.
Their fuel recirculation system consists of dumping any fuel buildup in the intake manifold, overboard. With a bad/mis-tuned carb this can be up to 1/3 of their total fuel.
They are made to run on a 24::1 gas oil mix. High speed and low speed jets must be set, after carb is cleaned. Setting high speed jets, in the boat, at full throttle is an experience.
They have 2 sets of points and a single condenser, magneto powered ignition system. It is very powerful, however, the single coil is subject to cracks in it's case and eventual failure. If the ign fails, check points, point wire and then coil.
They can be easily pull-started. The generator/voltage regulator do not age well.
Racer, I had two Fattys. Both had rounded off shift dogs. With careful adjustment I could get a solid forward or reverse, but not both, due to wear on the shift linkage, dog and gears. I chose forward gear, and learned to get by without reverse.
