water pump v belt pulley and shaft
mccldoub
Hello, my first post here, over the past couple years its been tough locating parts for older cobalts. Mine is a 19ft 2000 5.0L GL volvo penta SX. Trying to find a Volvo Penta Raw Water Pump V Belt dual Pulley with shaft. Or can that shaft come apart and used with new pulley? BTW i cant find squat on this haha. Thanks all!
bruceb58
Did you try here:
What is your complete model number?
You have a grey or red engine?
Raw water pumps of your vintage were not pulley driven. They were mounted on the crankshaft pulley. Which pulley are you actually talking about?
mccldoub
mccldoub
5.0GL PEFS and its grey. I have removed the water pump and I’m looking for the v pulley that was attached to pump. I rebuilt the pump and it does not seat up against the pulley shaft just slides right on. Thanks for your help.
Bt Doctur
depending on your motor .you can convert to a Bravo pump with a few parts
mccldoub
Here is what I’m working on.
bruceb58
Bt Doctur
after the 4th pump failure I convinced the customer to convert over.have all the pics and instructions.
bruceb58
Volvo has been using that same pump design for as long as Volvo Penta has been making stern drives. I would use it long before I switched to that Mercruiser design.
mccldoub
I would love to use it but cannot find the v belt pulley I need to make it work. My pump does not fit snug on shaft I can put it on by hand which is causing my leak (I think). Thanks guys.
Bt Doctur
the pump body should not be snug, only has seals riding on the shaft and is bracketed in a fixed position
mccldoub
Perfect! Most post I saw when rebuilding water pump showed them using a pulley to remove pump from shaft pulley. If it does not need to fit snug and just held in place with that bracket, then I need to check my water pump rebuild job.
bruceb58
I gave it to you already. They are available all over the place.
