5.0 Mercruiser MPI Broken distributor Screw hole
Status
Not open for further replies.
easyloader
One of the distributor screws hole is broken on a 5.0 mecruicser MPI. I can't believe the top of the distributor is plastic. I read that there is a repair kit for $25 but don't have any details.
Has anyone heard off the repair? Any details would be great.
Thanks
Stinnett21
Not sure what you are talking about. Can you include a pic?
easyloader
this is a picture from website, the distrubutor has a plastic base.
Bt Doctur
Yep, they are made out of plastic. I did a repair by removing the remnents and bolting on a piece of starboard , shaping to fit and drilled and tapped a new hole
Lou C
If you can fix it that’s good but a plastic distributor body and those infernal crab caps are 2 lousy ideas prepretrated on boat owners by either GM or Mercruiser!
There are aluminum replacement dizzys for about $110
easyloader
Should I go back with a mercuiser or aftermarket distributor with aluminum body?
$800 mercruiser plastic dizzy is a $80 delco dizzy (yes, a 1000% markup). go to your local NAPA and get a replacment
easyloader
Found a solution made for this issue. Not crazy about sheet metal screws. I'll try tapping out plate and using machine screws.
Dorman 90449 Distribution Repair Plate​
Status
