- Jul 23, 2011
- 53,022
while tail gunner brings up a good point with vinegar and oxalic acid. i wouldnt even worry about that little bit of staining. not worth the effort to pull the cam to soak the cam in oxalic acid.
stock compression on a 305 should be about 9.2:1 that is with stock GM flat-tops and stock GM small combustion heads with the 58cc combustion chambers.
