I have a 200 hp off shore carbureted engine SN 0G693618 . The boat is new to me and its not idling correctly. I know the P/O was a tinker because when I mentioned it he said you just have to adjust this screw a little and pointed to the max spark advance screw ... so before I go messing with anything I have some questions
1. How do I go about finding true tdc the manual says Turn flywheel in a clockwise direction until No. 1 piston is at top dead center set dial indicator at “O” (zero) and tighten indicator set screw... Ok did that but noticed the flywheel has a lot of movement on the rocker before it starts going down..
Turn flywheel counterclockwise until dial indicator needle is approximately 1/4-turn beyond .462 in., then turn flywheel clockwise so that dial indicator reads .462 in. (11.7mm) exactly. 4. Reposition timing pointer (a) so that timing pointer is aligned with .462 in. mark on timing decal. Retighten pointer attaching screws (b). 5. Remove dial indicator from cylinder..
So I'm assuming were only worried about .462 Correct which is wide open throttle ?
2. I still have the Idle Stabilizer Module Part # 87076A9 I've read that it might be a good idea to remove this Any thoughts? and this will change my timing setting so what should my new settings be and am I still marking .462 on flywheel or somthing else ... Right now they are
Maximum Timing: *(Models with Idle Stabilizer Module) @ Cranking Speed 22° BTDC
@ Wide Open Throttle 20° BTDC
Idle Speed/Pickup Timing 0°-9° ATDC ..
Thanks in advance
Mark
Thanks in advance
Mark
