40hp force outboard owners. year? And wire question.
bassmanhb
Just picked up a pontoon that has a 40 hp force on it. Problem is the serial number/year sticker is missing and I need to order an impeller for it. Any other way to determine what year it is? Also in the attached pictures the wire shown, where does it attach? And other picture where does the cylinder thing attach? Thanks.
The wire may be for overheat warning.-----The cylinder thingy is the ENRICHER.----Used instead of choke flappers.----It does not need to be attached to anything.
bassmanhb
Yup, on both. The wire isn't attached to anything for the high temp warning so need to know where it goes? Any idea on figuring out the year?
roscoe
1992-1994 used the old gearcase and prop style, like this:
1995 thru 1999 used the Mercury gearcase, with prop tab and nylock nut, like this:
bassmanhb
Roscoe thanks! Looks like it's probably the same year as the boat then, which is a 1993. Appreciate the help .
bassmanhb
Lol, thanks. That's what I'm trying to figure out! Can't find it on the schematics, and can't see where it goes to in pictures of this outboard.
jerryjerry05
Check the buss bar where the harness hooks to the motor harness.
It might be cut off ?
Tan wire, I think??
bassmanhb
Jerry, wires not cut off still has the end on it. Just cat find where it goes! Driving me nutz! Lol
jerryjerry05
If the wire has the end? post a pic?
The wiring harness from the dash should have a lead that connects to the wire,
It's possible it was cut or someone taped it back?
From the part I see(parts list) the wire should have a wire with a plug in connector?
bassmanhb
Here is a pic of the wire.
Legal, thanks will look it up.
