V4 on a v6 lower
Monaskon
I have a Grady with dual 120 evinrudes. Port motor has a new power head on a 90's model v6 mid and lower. I have a 93 v6 mid and lower,question is what v4 powerhead do I need to order to build same setup for the starboard. Motors started as 88 model year. Story is port powerhead would not come off of mid so they had a v6 mid and put the new powerhead on it.
----But pictures and model numbers are always helpful in these -----"Does anybody know topics "-----Battery is low on the cristel ball.
Faztbullet
Gear ratio is different between a V6 and V4 looper but can share the same big diameter gearcase. Put the port motor in gear and rotate the flywheel 1 full turn and count the rotations of prop.
Monaskon
I gotcha, question is will a v4 bolt to a v6 mid cause I have a 93 v6mid and lower,looks like what they did on port
