Gear oil hose
BobbyBerry
I have a 1996 3.0 mercruiser inboard engine and there is a hose attached to the reservoir for the gear oil. The other end of the hose isn't attached anywhere. What does the loose end connect to on the transom and how do I attach it? I'm not seeing a place for it on the transom.
Fun Times
Being an 3.0L engine/Alpha application yours may or may not have had an oil hose fitting installed form new as it was sometimes an option to have it in the earlier years but should it be there or someone fully installed the oil system then at the rear of the middle area of the transom assembly ought to be a fitting that looks like item 5 attached to item 1 of the following parts diagram, https://www.mercruiserparts.com/bam/subassembly/30860/1942/230
And/or at placement B_8
B
Image result for mercruiser gear lube hose fitting transom conection point
BobbyBerry
Thanks I appreciate your help
brunolund
should have a nipple for the hose seen here not sure why the pic is rotated F35BE3EF-6E7B-4536-BB5A-05D89B25A4FB.jpeg
