fast inflatable
johnny mav.
I have a 12ft novarania inflatable with a vee hull and a 70 hp evinrude what prop would you recomend for top speed
Sea Rider
What!!!! What's the max HP is the 12 Ft Rib rated for ? Was it rigged at a dealer or by an extreme boater ? Such size Rib with a 70 HP is surely over rated ? Needed Data for the rest of the equation :
-How many souls will be on board ?
-Current prop diam/pítch, number of blades ?
-Motor WOT RPM range factory stated ?
-Max achieved WOT RPM as loaded ?
To test the last two will need to buy an induction tach for a 3 cylinder motor, install it next to the tiller grip, program the spark firing sequence and go testing the Rib at open water.
Happy Boating
dwco5051
It has been a boring winter and I would love to go along on that test ride. That boat is rated at 30hp max. A little excitement to take my mind off shoveling snow.
Sea Rider
A 70 HP will blow not only your mind away, include yourself out of the Rib. Have you tested the combo package previously at wot ? The issue with a 70 HP motor it's darn s too heavy, will need a heavy champ to sit as a bow mask up front to balance and distribute the deck load evenly across the entire hull. If not the boat will achieve a bow up attitude.
Personally wouldn't dare install a 70 HP motor on a 3.65 Mtr Rib rated for a 30 HP motor, max would be a 40 HP one. At wot that boat should have a nervous behavior specially if tiller driven which don't know if it's the case ?
Happy Boating​
Stinnett21
I assume he's talking about an old Johnrude looper. Probably no heavier than the modern 40 4stroke. Sounds like a fun setup. Get ready to wear ear protection and goggles. She's gonna fly!
